abrasives and finish
发表于 2021-9-1 00:00:16 | 显示全部楼层 |阅读模式
I wasn’t sure the best place to post this, but I have a question regarding stainless steel surface finish. I am fabricating curved 14ga “box-constructed” forms (single plane flat and curved). Does anyone have any information or know where I can get information about the best way to bring a welded stainless steel surface to a mirror finish, and which abrasives I should look for?
Reply:Not sure about the welded part...but try Caswell Inc. at www.caswellplating.com.  They have more polishes and abrasives than you can shake a stick at and even SS KITS that contain everythign you need and will do the job nicely.  I haven't done anything with welded parts, or stainless, but if you look at my avatar, I used Caswell products to bring that axe up to a mirror finish.Contact me for any metal polishing needs you may have, my avatar is a pic of a standard, painted fire axe that I ground, sanded polished and buffed to a mirror finish.
Reply:Hey thank you a Lot for the reference. I found all of the info and "where to go" that I was needing on that Casewell website. appreciated!
GMT+8, 2025-12-24 00:56 , Processed in 0.121287 second(s), 18 queries .
