Well,I finally got around to builing some tables for the new shop. I needed a fairly flexable layout, so I decided to build 4 4'x4' tables. They're built from 2" square .120" wall tubing, with .5" tops. I work at a sign shop and need to build some rather large signs from time to time, but building a giantic single table wasn't really feasible, so I think this should work out pretty well for me. I can pull each table out to each corner of a sign and let the material span the gap. There is level feet on each table to true everything up. I only made the tops overhang on 2 sides, so I can bolt the legs together tight when I want a 4'x8' table also 2 of the tables have one side of the bottom aprons pushed back so I can pull a stool up for tig work. I still have to get some material for the bottom shelves, but I might try to hold off because I know it'll just collect junk down there. I still need to clean up the edges where I cut the tops. I'm not too steady with the plasma, so I have a fair bit of grinding to clean up the edges. Perhaps I'll have to buy a new 7" grinder as a christmas gift to myself to get it done a bit quicker. We just started getting the shop built out, so it's pretty much in shambles right now, hence the mess on all of the tables. Attached ImagesLast edited by jschulze; 12-24-2009 at 05:13 PM.Thermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Man, those look great. Sounds like you really thought them out and made a really useful and flexible table "system". I am very envious of your shop.Miller Millermatic 212... and that's about it... for now...
Reply:That's good thinking right there, modular tables. That red color jumps out at ya! Nice. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny |
