Simple Band Saw Roller
发表于 2021-9-1 00:00:11 | 显示全部楼层 |阅读模式
My Dad is 70 and just moved into a newer house with a smaller garage.  I didn't want to see him try to move his bandsaw around (as it is probably 150-250 lbs), so I built this simple roller for him.  Haven't posted anything in a while, so thought I would post this. Attached Images
Reply:More . . . . Attached Images
Reply:another . . . Attached Images
Reply:Awesome Job !  ...Love the look and it matches the Bandsaw Stand Perfectly.I plan on making some similar ones for my Wife's Grandpa so he can take his tomato plants in (10 - 5 gallon buckets) when we get 'Frost Nights' late in the growing season !Cheers,/Jman..Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Very clean!! I like the expanded metal bottom; easy cleaning and some storage.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-24 01:14 , Processed in 0.123592 second(s), 18 queries .
