Security fence & gate
发表于 2021-9-1 00:00:08 | 显示全部楼层 |阅读模式
Here is a link to the pictures. http://bdowdy.smugmug.com/Welding/Ci...31710890_SjX2vDynamic MetalworksMontrose, CODynMetalworks.com
Reply:nice work
Reply:That's purdy.Gud werk.
Reply:the pit bull of fences
Reply:I like your sign!  How was the lettering cut?Looks like someone already tried to climb the fence and the end picket next to the building.  Looks like the top brace broke off when they pulled on the picket and bent it.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Very nice work!From the point of security it seems that the deterrent on top of the gate is a little short. It looks like the horizontal member could be used as a step and one could throw a piece of cardboard over the top and slide over.Just an observation.
Reply:Hello Bryan,                 Nice work,cut-out name plate excellent touch. not keen on the gaps in the pickets at the top from a security and appearance point of view. I would like to see an extra one welded on top of each post to match the rest.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:That middle bar in the gate needs to go.  Unless YOU like supplying the ladder.My name's not Jim....
Reply:Originally Posted by DesertRider33I like your sign!  How was the lettering cut?Looks like someone already tried to climb the fence and the end picket next to the building.  Looks like the top brace broke off when they pulled on the picket and bent it.
Reply:Hello Bryan from just down the road in Yukon!!!Where is that at? Looks way too clean to be in OKC!Flashhttp://flashracecarbodies.com
Reply:Originally Posted by BryanDowdyThanks. This spikes are 4'' tall and are very sharp. My helper cut his arm while we were installing them. I agree the horizontal piece was a bad design idea, but our thought was even if you use the horizontal piece (which is on the inside so it would be hard to keep your foot on it) you would still have to slide on you stomach over the spikes.I am always open to constructive criticism, how would you have designed the gate top?
Reply:I took another look at the pictures and I suppose it could be possible to use the horizontal members to climb over the gate hinge locations. Maybe another tall spike is needed above each hinge post. Either that or some grease on any obvious climbing/stepping points.In any case very nice work.
Reply:I like your rig setup. It's impressive considering you didn't have to get a custom bed. Good job!Lincoln Ranger 250- Kohler 23hpVictor SuperRange II torch03 Ram 3500
Reply:Originally Posted by newI like your rig setup. It's impressive considering you didn't have to get a custom bed. Good job!
GMT+8, 2025-12-24 01:15 , Processed in 0.224208 second(s), 18 queries .
