Needed cutting torch kart
发表于 2021-8-31 23:59:56 | 显示全部楼层 |阅读模式
Had tanks no kart. A little pipe, flat plate , diamond plate and go kart wheels. After it was built I had it powder coated. The flat bottom was Rino sprayed. A little diamond plate box on the back mad into a box. Who says karts and welding equipment has to look dirty and un kept? Attached Images
Reply:Looks good. Definitely different. I like the wheels.
Reply:That is the fastest looking torch cart I've ever seen. Cool!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Get some fenders on it and paint flames on it!
Reply:Needs some sweet wheelie bars so it cant tip over.  would fit the look almost perfect.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I used a moving dolly I had laying around and put a strap around it. Works great.
Reply:Slicks are off set to the back of the kart. It cant tip over. Fenders? I never thought of that. Maybe Chrome with diamond plate mud flaps
Reply:Let's see it all filled up.Only two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
GMT+8, 2025-12-24 03:08 , Processed in 0.436592 second(s), 18 queries .
