my table and cart
发表于 2021-8-31 23:59:56 | 显示全部楼层 |阅读模式
table before expandedand after bottom shelf was installedtop and bottom of cartcart completeyes they still need sand blasting and paint, it'll be some time before that's done though, I don't even have a compressor yet.
Reply:I think they look pretty good.
Reply:wow ...nice effort man ... great job .... and good work ....!!!i also need to have such kinda material for my new project .....steel bar steel supplier
Reply:Looks nice. Normally when building things with expanded metal, I put the expanded sheet on top of the frame, so the frame supports the sheet and weight of whatever will be loaded on it, instead of all the stress being on the little tack welds.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Looks nice. Normally when building things with expanded metal, I put the expanded sheet on top of the frame, so the frame supports the sheet and weight of whatever will be loaded on it, instead of all the stress being on the little tack welds.
GMT+8, 2025-12-24 01:11 , Processed in 0.098987 second(s), 18 queries .
