air tool holder
发表于 2021-8-31 23:59:55 | 显示全部楼层 |阅读模式
Needed a place to hole tire air tools. Heated scrap. Bent it into right angle. Cut 3/8 slots in it. Had it powder coated. Had a spare decal. Did a little hand painting. Attached Images
Reply:Do they slide in the slot?I may purchase a compressor in a month or so.Dave ReberWadsworth Ohio
Reply:Yes they slide in the slot. I first drilled a 3/8 hole 1 inch form the end. Then drew lines from the outide of the hole to the edge. I used a cut off wheel and cut to the inside of the line. Kept checking as I went along. Another way a 3/8 end mill and a drill press will make life easy on these.
Reply:I bought a bunch of cheap, male threaded couplers from Harbor Freight.  Drilled and threaded holes in some angle iron and hung them up out of the way.  I plug in my tools to hang them.America Needs AMERICA'S Oil!!!"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
GMT+8, 2025-12-24 01:11 , Processed in 0.077068 second(s), 18 queries .
