My projects
发表于 2021-8-31 23:59:54 | 显示全部楼层 |阅读模式
First time posting a pic. 8' box plow I built five years ago. Blade is 1/4", ends are 3/8". I have to bend the sides back into shape and reinforce them at the bottom. Attached ImagesLast edited by Stick-man; 12-30-2009 at 08:19 PM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Here is the 10' big brother. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:And an 80" wide oversized snow bucket to go with those. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I had some left over rebar from a bridge deck and I decided to make a tire inflation cage. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:A wrecking pole / lifting boom. Outer tube is 5"x7" 3/8" wall inner tube is 4"x6" 3/8" wall. I would make some changes if I made another. I built this from a friends description over the phone. Anyways it has lifted 2'x2'x6' concrete blocks which weigh around 3200 lbs without a budge. But that was with the cable back by the side braces. The arrow head is 5/8". Attached ImagesLast edited by Stick-man; 12-30-2009 at 08:45 PM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I had a vise sitting under my work bench for years. I finally decided to put it to good use. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Ok, this is what I call a heat pipe. You put a torpedo heater in front of the box end and  I use it in the winter under my tow behind air compressor. It heats up the engine compartment so it will start like its summer. It's an air cooled engine so no block heater and no glow plugs. I like to be nice to my equipment. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:My welder, wire feeder and plasma cutter on the rack I built. Attached Images"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Very Cool Stick Man. How well do the box plows work on the Skid Steers? And that 8' Snow bucket is well all i can say is wow. That would pack a crap ton of snow.
Reply:Originally Posted by CrickertjVery Cool Stick Man. How well do the box plows work on the Skid Steers? And that 8' Snow bucket is well all i can say is wow. That would pack a crap ton of snow.
Reply:So what go you do at your day job? I mean besides kill zombies with the Bobcat mounted harpoon?I'm guessing you do concrete/excavation from the rebar, demo gear and air compressor. Nice work. Yard looks alot like where I used to work when I did that sort of stuff..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWSo what go you do at your day job? I mean besides kill zombies with the Bobcat mounted harpoon?I'm guessing you do concrete/excavation from the rebar, demo gear and air compressor. Nice work. Yard looks alot like where I used to work when I did that sort of stuff.
GMT+8, 2025-12-24 01:07 , Processed in 0.094700 second(s), 18 queries .
