4bt cummins jeep build log
发表于 2021-8-31 16:58:53 | 显示全部楼层 |阅读模式
I have been in the process of building a 3.9l 4bt cummins to transplant into a 2000 jeep tj sport Engine build specs-std pistons with ceramic coated crown-acd stage 1 cam-head completely rebuilt with new valve seats, guides, and new valves-all new bearings from acd-acd fuel pin and 3200 rpm gov spring in the ve pump-he341 also known as hy35d turbo from a 2004 5.9 cummins with a 9 cm exhaust housing-5.9 exhaust manifold cut down to fit the 4bt and ports reshaped Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:More views of the project Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Few more shots Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is are some more angles and a shot of the 2004 common rail cummins I put in my 1999 f250 in 2011 Attached ImagesLast edited by jbr; 05-17-2015 at 06:23 PM.LONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is a shot if when I was working on porting the head Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Been working on the bell housing, it had to be modified to clear the shifter boss on the nv3550 Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Wrapped the exhaust manifold with titanium wrap Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started working on the turbo piping Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Interesting build, looking good so far.Is that poor little jeep going to be able to hold that 750lb motor? Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverInteresting build, looking good so far.Is that poor little jeep going to be able to hold that 750lb motor?
Reply:Built a mout for my tubing notcher Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Cut apart a intake elbow from a 24v cummins and will tig weld it back to be used in my configuration Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Welded the cast aluminum intake back together Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:All done Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Test fit the modified elbow Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:The intercooler also came in Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Downpipe flange is welded on Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Starter clears Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is a link to the turbo mount I built http://forum.longevity-inc.com/showt...in-turbo-mountLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Trying to find the right spot for the intercooler Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Version 2.0 of the turbo set up Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started building the alternator mount Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started mocking up the air con compressor Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Very nice build... Now this is going into a jeep? Lol my goodness this is going to be a tight squeeze!! The weight on the front end... what type of Axles are you going to be running? I would suggest something on the lines of a Dana w/ 4.10 gears. Your putting a 5.5 lift on the front and rear correct? Is it going to be coil over springs? Do you know the Gross weight on that engine after its all said and done with your add-ons? You will have to cut your hood and put a very large Cowl on there. with real air intakes. I am sure you have measured your clearance?Last edited by AndrewDavenport89; 06-11-2015 at 02:25 PM.
Reply:Originally Posted by jbrThanks, to get the 3" of lift I need I think I will have to put 5.5" lift springs in but I will have to spend a little more time researching and doing the math, I plan on strengthening the frame in certain areas as well, if anyone has ideas please post them upI am using these springs from a 1979 broncoSent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Air con bracket progress Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Yea that springs right there will hold some weight lol(I am referring to the spring on the right). I forget, but the shock rides on the inside of the spring and it all sits on top of the front leaf springs correct? Have not looked at that model jeep in a long time. How much longer until you start working on the truck itself? You just about have the diesel wrapped up. Just a few more bells and whistles.
Reply:Originally Posted by AndrewDavenport89Yea that springs right there will hold some weight lol(I am referring to the spring on the right). I forget, but the shock rides on the inside of the spring and it all sits on top of the front leaf springs correct? Have not looked at that model jeep in a long time. How much longer until you start working on the truck itself? You just about have the diesel wrapped up. Just a few more bells and whistles.
Reply:Originally Posted by MountaineerMetalThere are no leafs on a TJ, it is a coil spring setup, you would never have both as that would make for a very intersting ride with 2 springs constantly fighting each other and the shocks are outside the springs.
Reply:1979 bronco springs are installed Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Alt bracket is almost done Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Recent progress Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is a closer look at how I mounted the air con compressor, it is not completely done as of now Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started tearing down the jeep and get ready to fit the 4bt cummins and build motor mounts Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:I broke the dipstick shroud so I made a new out of stainless steel Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started fabricating the heater core plumbing Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Gasser is out Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:4bt cummins / Ford bellhousing mocked up on the nv3550 transmission Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Added some color to the transmission Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Transfer case got a coat of por15 Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here a different angle Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is some axle info http://www.fourwheeler.com/how-to/15...r=134572609342LONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:The face offSent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Got the flywheel back from the machine shop and went to work on the clutch, I sourced a new pilot bearing from the local bearing supply but the minor diameter is 1mm to large so I made a bushing the is pressed into the bearing and has a good slip fit over the input shaft Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:It's getting crowded in here Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Started fabricating the turbo oil supply line Sent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Photo op of the tig welder Attached ImagesLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:I have been away for a while but I am back on the Cummins project building motor mountsSent from my SM-G900V using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
GMT+8, 2025-12-19 00:37 , Processed in 0.103050 second(s), 18 queries .
