Corrugated plate. Where to get?
发表于 2021-8-31 23:59:50 | 显示全部楼层 |阅读模式
I'm doing a little searching for a buddy. They are looking to buy sheets of corrugated plate (3/16 x 8' x 10' or 20' ) . They are trying to build some tanks for the oil industry.  We are located in northeast Ohio . Any help or leads would be appreciated. I really can't answer any questions since. I'm just trying to help them find the material.Any help would be appreciated. Thanks .
Reply:I have never seen "corrugated" plate as a standard mill product, doesn't mean it isn't available somewhere.  Closest thing I have seen would be sheet piling which is much thicker than what you are specifying.You will probably need to get a steel fab shop to run a flat plate through a press to get what you want."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:what your wanting is a fabricated product.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-24 01:11 , Processed in 0.099335 second(s), 18 queries .
