spool gun for millermatic 135
发表于 2021-8-31 23:59:47 | 显示全部楼层 |阅读模式
Hey guy's, i have a millermatic 135 and want to weld aluminium without spending a bunch of money for a tig or a much bigger mig. Do you have any suggestions on spool guns that will work with my machine that wont set me back the $500 dollars or so for the miller spool gun. Thanks for your reply's.
Reply:Not only will you need the $500 sg you will need a $400 controler to run it......looks like time to up grade or go for a TIG.Mike
Reply:Thanks for the input Mike. I forgot about the controler, damn. What machine would be a good inexpensive upgrade for the mig. or even a good tig.
Reply:Dav I wouldn't try al with anything less than a 220 v machine with the exception of a Passport Plus.... I love my HH210 and it was $1300 out the door with the SG........the MM180 and spoolmatic 100 isn't much less and from others that have the HH210 and MM210 they will reach for the Hobart first if the job is within the Handlers limits.....a "good" starter TIG is hard to tell ya as some could be fine with an econotig vs some would be better to start out with a dyn 200.......
Reply:Here is a good price....and if you have a Northern tool they wil match it as well.Mikehttp://www.toolfetch.com/Brand/Hobar...ers/500526.htm
Reply:Thanks Mike, looks like i need to look into a new tool. I got the millermatic for welding up a harbor freight trailer we were making into a teardrop trailer. Never finished the project after the welding part, maybe someday we can get back to it. I've never done any tig welding but mig is to fun.
Reply:The controller is only about $250 new (SGA100) and will work with the 3035 spool gun, which you can pick up used for about $300 if you are patient and keep a look-out.If you want a new mig with a spool gun, Miller has the Millermatic 180 that now accepts a Spoolmate 100 gun as a direct-connect without a controller and the gun only cost about $200 when purchased seperately.   I don't know if they still have the sale going on but recently they had a sale where if you buy a new Millermatic, you can get the spool gun with it as a package for only $100 more, which applied to the 140, 180, DVI2 and Passport mig welders.You're going to spend ALOT of money if you want a new ac/dc tig machine.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:One other idea I forgot is HTP has some deals on spool guns that can connect to various welders.  They have a model that connect to Millermatics and another that can connect to any constant-voltage dc welding power supply that comes with it's own controller.  Their prices are very reasonable.  Try www.htpweld.com.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:so the cheapest way into aluminium welding is a mig with a spool gun?
Reply:Thanks Desertrider for even more options.
Reply:Doesn't Miller make Hobart or vice versa. I like my miller machine and would want to stay with a miller brand, i'm just quirky that way. But getting a better tool is always my goal so i could stray from it.Millermatic 135Lincoln Electric AC/DCClarke weld 131eParker Metalworking-40A plasma/160DV DC tig/ stickIf it's stuck, force it, if it breaks, it needed fixing anyhow
Reply:Miller and Hobart are both owned by ITW and share some parts as well.
Reply:i think the ta185 is the best deal to get  acdc tig
Reply:Originally Posted by weldbeadi think the ta185 is the best deal to get  acdc tig
Reply:Thanks guys, just a guess but is the ta185 the thermal arc 185? I'm not familiar with all the diferent brands of welders.  DaveMillermatic 135Lincoln Electric AC/DCClarke weld 131eParker Metalworking-40A plasma/160DV DC tig/ stickIf it's stuck, force it, if it breaks, it needed fixing anyhow
GMT+8, 2025-12-24 01:11 , Processed in 0.201257 second(s), 18 queries .
