Any TIG experts in GA?
发表于 2021-8-31 23:59:45 | 显示全部楼层 |阅读模式
Around Athens or Lawrenceville or Commerce or??I need someone who can reliably weld aluminum.I've got a truck bed that is aluminum that some idiot drilled a bunch of holes in.I'd like to TIG weld some plugs for those holes.  But I can't have any heat distortion . . . so I'm afraid to do it myself.I've gone and re-counted the holes . . . there are approx. 2 dozen of them.  Most are about 1/4" in diameter.  I think the aluminum is approx. 1/8" thick.  I'll need to double-check that.These plugs will be smoothed out and line-xed over in most places.  About a half dozen of the holes are in areas that will be repainted.Anyone think they can help?  Or point me in the direction of someone who can?Obviously, I wouldn't expect anyone to do this for free.Thanks
Reply:I'm sure "Tubularfab" a member on the forums here could handle that for you. Not sure how far apart you guys are.  He is up in Braselton.  I'm down in southwest GA, but there are some others up in that area as well.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-24 01:10 , Processed in 0.096121 second(s), 18 queries .
