Stainless Grades
发表于 2021-8-31 23:59:42 | 显示全部楼层 |阅读模式
Hey guysMy mate's grandfather recently died and he wants me to make a ornamental that matches the other graves. So my question is what type of stainless should i use i was thinking about 309 but which one would hold up to the elements the best? Thanks Steve
Reply:308 should be fine.I typically use 309 filler when welding stainless steel to mild steel.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:This will help you choose.http://en.wikipedia.org/wiki/Stainless_steel
GMT+8, 2025-12-24 01:09 , Processed in 0.077631 second(s), 18 queries .
