using a remote on a Lincoln precision tig 175
发表于 2021-8-31 23:59:39 | 显示全部楼层 |阅读模式
Hello All,            I have a lincoln precision tig 175 and i thought about making an remote amperage control for stick welding. I would mount a potieonometer in a box and then connect it to where the tig pedal plugs in with a length of wire. Then when i weld i would have to flip the swith to tig  whit this i would have the control and be able to adjust the amperage where i am working. I was wondering if anyone could see a reason that this would be a bad idea.
Reply:Originally Posted by ar15is223Hello All,            I have a lincoln precision tig 175 and i thought about making an remote amperage control for stick welding. I would mount a potieonometer in a box and then connect it to where the tig pedal plugs in with a length of wire. Then when i weld i would have to flip the swith to tig  whit this i would have the control and be able to adjust the amperage where i am working. I was wondering if anyone could see a reason that this would be a bad idea.
Reply:ok thanks i will give it a try
GMT+8, 2025-12-24 01:08 , Processed in 0.170453 second(s), 18 queries .
