binzel push pull manual and adapters
发表于 2021-8-31 23:59:36 | 显示全部楼层 |阅读模式
just got a binzel ppg 22kd push pull off ebay 120.00 ben trying to find a manual so i can hook it up to my sp32 suit case or one of my other toys it dosent have the end that hooks to the machine just the scew part on the end of the whip anyone know where i mite find one thanks dalemiller trail blazer ,miller bluestar,licoln tig 300/300 ,lincoln buzz box ,lincoln hi freqency box, 2 super s32p suitcases ,miller matic mig, ln7,60 inch southbend lathe,craftman 110 mig, L TECH 250 HF, binzel push pull gun ,36 inch hendey lathe
Reply:found some on ebay i thought it would be hard to find becaus i got it so cheapmiller trail blazer ,miller bluestar,licoln tig 300/300 ,lincoln buzz box ,lincoln hi freqency box, 2 super s32p suitcases ,miller matic mig, ln7,60 inch southbend lathe,craftman 110 mig, L TECH 250 HF, binzel push pull gun ,36 inch hendey lathe
Reply:Binzel Part # 601.1828 is the adaptor you need.You can call tech support at 301-846-4196 ext. 159 if you have any questions.
GMT+8, 2025-12-24 01:10 , Processed in 0.098520 second(s), 18 queries .
