Used / Reasonable Miller Welder Parts?
发表于 2021-8-31 23:59:35 | 显示全部楼层 |阅读模式
Anyone know a source for reasonable priced or used parts for Miller engine drive welders?I need a new fuel tank, radiator & rectifier assembly for my Big 40 Diesel. I've found a place that at least has prices for OEM parts, but the tank is $850, radiator $1200 and the rectifier $350. The biggest thing is the fuel tank. The radiator I can get recored locally for about $400, and the rectifier I doubt I'll get much cheaper. The tank had major rust issues, i hot tanked it and it came out looking like swiss cheese, I soldered the pinholes, acid washed it several times and lined in, it seemed to be ok but now I've got at least 2 pinholes weeping... so time for a new tank. Somewhere someone has used parts for these, any thoughts?Thanks,     ~John
Reply:Originally Posted by sdmulemanAnyone know a source for reasonable priced or used parts for Miller engine drive welders?
Reply:http://stumpfweldingsupplies.com/"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Kelvinhttp://miller4less.com/
Reply:Thanks all, definitely a set in the right direction. Still pricey, but I guess that's the name of the game with the things.
GMT+8, 2025-12-24 01:11 , Processed in 0.100880 second(s), 18 queries .
