My first TIG welds
发表于 2021-8-31 23:59:34 | 显示全部楼层 |阅读模式
Let me know what I can do to improve and what I am doing right as well as wrong. One pic of several steel welds and one Alum weld.
Reply:id say you could run them a bit colder, but then again in most cases being to hot wont really hurt anything but appearance.Have we all gone mad?
Reply:Just keep doing what you are.   Practice Practice........Looking goodDavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Like above...Practice!Work on the stops..No cratersAlso try to keep in a straight line..Make it like a game..See if you can get in a rythem and make all the beads the same..Same # of dips in a certian space..Try to have a little fun..Happy goes a long way.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What they said, heheh. Looking good.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:How do I stop I have been ramping down the heat at the end cause it is carrying so much heat at the end of the weld. How do I finish correctly.
Reply:feed a little more rod and sit in the end spot and slowly let off the pedal. not super slow but youll see.6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
GMT+8, 2025-12-24 01:11 , Processed in 0.100781 second(s), 18 queries .
