Welding square stock to round stock
发表于 2021-8-31 23:59:31 | 显示全部楼层 |阅读模式
I need to weld a 1" square tube parallel to a 1.5" round tube. Is this feasible (practical) using MIG? Will I have to make multiple passes to fill the "valley"?Lee TiltonSCCA F500 Pilot
Reply:I don't see why not.  As far as the multiple passes I guess it would depend on your weld procedure.  I would think I could flush that with a single pass.  A pic of how it will be used might help us understand a bit better what you are trying to accomplish.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Here are a few pics of the project. The rear clip will support a 120 lb. motor but have very little other forces on it. The suspension is not attached to the clip. Attached ImagesLee TiltonSCCA F500 Pilot
Reply:Looks good to me. I would however remove the paint and rust before welding.
Reply:Originally Posted by big wormLooks good to me. I would however remove the paint and rust before welding.
Reply:One pass should be plenty. I'd do the step and pause to get good penetration and fill. That is a pretty slick job on that motor cart, by the way. Looks nice.Good welding.P.S. Definitely ixnay the paint!!!
GMT+8, 2025-12-24 01:27 , Processed in 0.093194 second(s), 18 queries .
