Oops!
发表于 2021-8-31 23:59:31 | 显示全部楼层 |阅读模式
Time to call it a night!Just went up to the shop for a simple 5 min. job of welding some 1/8 AL brackets.  Fired up the TIG, tacked it up, grabbed the filler and went at it.  Man this is not going well I though.Looked at the settings, ya they look ok, but I just can't get this filler to flow!So I figured it must need a bit more heat...  SPLAT!  WTF!  never had AL go this bad!  Looked at the number on the filler rod 308L!  That would explain a lot! I think that is a sign to stop for the night.Me!
Reply:haha thats pretty funnywhat i do is i get pvc pipe, about 2 inch diameter and glue a cap on one end, then write the material and size of filler on the other endmake a rack for all the different fillers you havelooks cool and makes life alot easier
Reply:I have them in tubes, but somehow one got mixed into the wrong spot...Me!
Reply:sounds like something id do haha
GMT+8, 2025-12-24 01:54 , Processed in 0.126808 second(s), 18 queries .
