Steel's In!!
发表于 2021-8-31 23:59:22 | 显示全部楼层 |阅读模式
Temps are up, and the metal is rolling inPicked up my order over in Stillwater today.  4 pieces of sheet metal rolled to a 12' radius, and 12 pieces of plate cut into bows also 12' radius.Some cool machines  Had to hold a 12ga pump to the man's head, but I brought home the picsAnd nothing fell off on the way home Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Plasma does a beautiful job  Almost like a machined cut, and far superior to shearing. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:looking good Samm
Reply:Originally Posted by farmersammPlasma does a beautiful job  Almost like a machined cut, and far superior to shearing.
Reply:That's quite a burning table.Notice that it has an O2 and a plasma torch on the gantry?The O2 is liquid, instead of high-pressure. Liquid O2 is a "use it or lose it" system, with a finite life to a fill. To justify the boil-off of a liquid tank  they must be running high volume.Thanks for the pics Samm.
Reply:Originally Posted by oxy moron whats the world coming to? samm said "plasma does a beautiful job" instead of "I cudd-a done bett-ah with an OA torch"you gonna vote democrat soon too?
Reply:That will make you a fine piano Sam, don't forget to let Clarence tune it thoughDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Don't want the boinggggggg to go out of my springyyyyyyyy metal while it's waiting to be usedCargo straps(I need to get a life) Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Well gee Samm, if you had those, why'd you spend all that money on having them rolled? .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Samm, what is the metal going to be used for?  Always interesting seeing the next project on the farm but don't remember reading what this is for.
Reply:Originally Posted by ponch37300Samm, what is the metal going to be used for?  Always interesting seeing the next project on the farm but don't remember reading what this is for.
Reply:I sure would like a set of rolls like that.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-24 01:26 , Processed in 0.111520 second(s), 18 queries .
