Need help on PONY cart
发表于 2021-8-31 23:59:22 | 显示全部楼层 |阅读模式
I am still working on my fab skills. I am building a pony/ llama cart and want your opinions on what tubing should be used.  I am torn between 1x1x 1/8 or 1x1x.083  The .083 weighs in at 1.04 #'s/ft and the 1/8th is 1.44 #'s per foot.  Will the thinner stuff hold up to 250 pounds if spanned 2 feet max?Miller 185Lincoln Weldanpower 225Lincoln 225 buzz boxCheap-o C&H 110v (my first welder)
Reply:being  a rolling weight.  it should not be much to pulli would go with the thicker gauge, less likely to bendidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Thanks for the input,I was getting concerned as I started adding up the linear footage of the steel.  It will take approximately 32 feet just for the frame and seat supports and that does not include the pull bars, wheels etc.Miller 185Lincoln Weldanpower 225Lincoln 225 buzz boxCheap-o C&H 110v (my first welder)
Reply:A fairly nice material for those kinds of things is 1"x2"x about .070" wall tubing. Depending on the orientation it can add some rigidity vs 1" box and trying to overwhlem it with thickness. Just a thought.
Reply:One other thing you might think about is that taller tube will bend less than square. 1 1/2" x1" .083 (14g) is 1.32lbs/ft. 2"x1" .083 is 1.6 lbs/ft.2 1/2" x 1" .083 is 1.88 lbs/ft3" x 1" .083 is 2.16 lbs/ft.Determine the members that need the most strength and then up size those (using the tall side up) while keeping others lighter..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I appreciate the input, it looks like 2x1 may be a good choice for the framing.Miller 185Lincoln Weldanpower 225Lincoln 225 buzz boxCheap-o C&H 110v (my first welder)
Reply:Have you ever looked at a commercial one to get an idea of what they think should be used?
Reply:Originally Posted by BobHave you ever looked at a commercial one to get an idea of what they think should be used?
Reply:That is fantastic, and the last line is even better.Watch The Book Of Eli Movie Online Free
GMT+8, 2025-12-24 01:26 , Processed in 0.102356 second(s), 18 queries .
