Hand rail deflection clamp
发表于 2021-8-31 23:59:21 | 显示全部楼层 |阅读模式
Here is another shop tool that I made.  It's so you minimize deflection on the top rail when you weld legs on.I fabricated one a while back for pipe, but it walked off somewhere, so I had to make a new one. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Just curious....how often do you use it?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Do you crank down on it prior to welding, or just tighten it enough to make moderate pressure?I'd like to be able to put some camber on stuff prior to welding, but never know how much to do."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I've used this one for 150' of this job.  As for pressure?  Crank it down tight!  I've never had it deflect the wrong way.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Dang!!! now that's one I coulda used a couple of weeks ago.
Reply:I wonder if that would work to keep trailer frames from pulling when welding cross members or whatever?  Seems to me the same concept as you have shown in your pics.  Be interested to see some trailer guys chime in, or am I off frequency?GeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:now that's slick
Reply:How long do you leave the clamp on there after you've done the weld?
Reply:I would imagine if you had a wide enough clamp it would work on trailers.  But I would imagine that you would want more than 1 of them.  I'm kinda thinking the same thing on the rails I have been doing.I just leave it on till it's not too hot to the touch.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Excellent idea. QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:hmm in all the hadrails i have ever built i have never had that problem maby cause the way that i weld it so it dosnt draw on me as much hmmm i guess each to their own cool idea for other  apps thoughLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Originally Posted by geezerI wonder if that would work to keep trailer frames from pulling when welding cross members or whatever?  Seems to me the same concept as you have shown in your pics.  Be interested to see some trailer guys chime in, or am I off frequency?
GMT+8, 2025-12-24 01:29 , Processed in 0.091980 second(s), 18 queries .
