Fence Panel Size?
发表于 2021-8-31 23:59:20 | 显示全部楼层 |阅读模式
Hello, this is my first post. I have been viewing here for a few years.My question is I am getting ready to build some ornamental fence panels with the pickets on 6'' centers. How do you guys figure your panel width? I was thinking of doing 8'. I have tried figuring 7', 8', & 9' panels and doing any of them I will end up having to do a smaller "filler" panel at the end. Is this how its always done? I have seen fences before with no filler panels, I guess these just happened to be the right amount of fence. Thanks for any input.
Reply:should come out even 8 ft would be 96 inches didvde by 6" would give 16 picketsidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Prop, Maybe you meant 16 6" spaces, or a 1/2 space  on each end, but anyway, the pickets take up space too.PFD402,  Do you mean calculating the panel size for an entire run, so that there is no partial panel in the run?Good LuckLast edited by denrep; 01-14-2010 at 08:09 PM.
Reply:Six inch centers won't meet most building codes.  The four inch ball is a pretty common rule of thumb for the gaps between pickets.  You shouldn't be able to pass it through the fence.When I did my fence, I did 8' panels.  On the front side, I had one 7' panel, which I was able to put in the center (since my total panel count was odd on that side).  You'd never notice it was shorter than the other four.  If I'd put it on one end, I don't think that would be the case.If you can't space all the pickets uniformly, make the odd gaps on both ends of a side.  Make them the same width on both ends.Also work out if you're going to have the laterals slope with changes in topography or if you're going to keep them level and have the fence itself move up and down in steps.  If you're having it rise and fall in steps, you might want shorter panels rather than longer.Jack OlsenMy garage website
Reply:Jack, I think that 4" code only goes for railing. I think it's OK for a fence.Just order a bar from King Supply, prepunched at the 6" spacing you want and use it to lay it out. Soooo easy. About $20.
Reply:I kind of thought he was refering to the overall run of the fencing.  I guess I would use the run that would fit, up to 8 feet.If you are confined to a specific boundry and cannot fudge the fence, then cut a couple/few of panels longer or at odd length.  a few panels 6 inches longer is less noticeable than a 3 foot short panel.  If there is a gate some difference can be made up there.  A lot of the fencing with short filler panels is prefabed stuff that comes in stock lengths. If you are the builder and installer then you can make it work and use it as a selling point for your next job.
Reply:for handrails the code is so that u can not fit a 4" ball through the picketts but on a fence 6" spacing is just fine double check your codes though every where is diff also so you dont have like a 3 ft filler panel at the end just need to use some math and find out what size panel will work for your run with out having to use a filler should all work out in the long and short run lolLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Yes I mean figuring the panel size for the entire run. The run is 83.5'.Yeah I checked, 3/4'' pickets on 6'' centers will pass code.Thanks everyone for the help.
Reply:6" spacing  will save material, hence 6.75" centers.
Reply:PFD402 - Another important factor is to not waste rail material, so panel length should consider getting maximum out of each length of stock.Good Long
GMT+8, 2025-12-24 01:28 , Processed in 0.115555 second(s), 18 queries .
