Hydraulic Press Part.
发表于 2021-8-31 23:59:19 | 显示全部楼层 |阅读模式
I came across this pic of a part I tig welded a couple of mouths ago, thought it might be of interest. I will post pics of the finished press when I get a chance. Regards,Last edited by David R; 01-17-2008 at 06:17 PM.Reason: fix pics
Reply:WOW!I like the inside corners.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:very nice.
Reply:...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Not only are you a good weldor, but a good photographer too.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:That's a pretty weld, good job!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:HOLY MAN ALIVE!Nice!I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
Reply:Originally Posted by David RNot only are you a good weldor, but a good photographer too.
Reply:Burnit, try using a tripod...it works wonders.  Either that, or use flash. You will have no luck with no flash and no tripod, at least in my experience.I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
Reply:Macro setting..You don't get a flash but with a steady camera and the right lighting  ....Thats what I use 90% of the time.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:BeautifulMiller Dynasty 200DX Tig Welder
Reply:Thanks everybody for the kind replies.
Reply:Did you use pulse?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Excellent, Beautiful looking welds. Cool clean photos. Why do you put two cents in when its only a penny for your thoughts? Miller Thunderbolt AC/DC Millermatic 150
Reply:Nice looking job there Propulsion!super critical review follows:slight undercut in pic #1, left corner as you went around the corner of the piece.  Also, weld looks a little flat, could use a little more filler to get the bead slightly convex.  Especially when you turned the corner, that bead area looks concave.In pic #3, as you went around from the inside of the channel to the outside on the right leg, you did a stop/start right on the corner and you also didn't wrap the two welds over one another all the way.  Roll the beads and starts/stops past the corners.  There is usually enough going on at corners without adding any additional stress risers from starts/stops.But man, you had a rhythm going on there!  Nice tight consistent ripples.
Reply:You know, I really think those pics fall under the category of too nice to criticize!  You obviously know what you are doing to weld that consistently...So, I'm also wondering if you were using a pulse at a pretty high frequency.  That would be my guess...
Reply:nice burning dude, gotta love tigging!!! so clean!
Reply:No pulse, no welding positioners, just thru it on the table and welded it out in the open. To be honest, I really do not care for heaver welding on thick plate like in my pic, as I have to wear those awful heavy mid evil gloves.David R, Sorry for not getting back to you sooner.Last edited by Propulsion; 01-20-2008 at 11:27 AM.
Reply:sweet looking welds and the pic'sChuckASME Pressure Vessel welder
Reply:looks good
GMT+8, 2025-12-24 03:16 , Processed in 0.103832 second(s), 18 queries .
