Oil pans?
发表于 2021-8-31 23:59:17 | 显示全部楼层 |阅读模式
Notice how many oil pan threads there are all of a sudden? Wtf? There are strange forces afoot! Multiple forums. Just search oil pan for all forums.
Reply:Originally Posted by MoparfeverNotice how many oil pan threads there are all of a sudden? Wtf? There are strange forces afoot! Multiple forums. Just search oil pan for all forums.
Reply:The terrorists are trying to knock out America's transportation network by knocking holes in everyones oilpans. Or maybe they figure if we are leaking oil, we will have to buy more of their oil to replace what is leaking out. Thus adding to their coffers, financing their operations. They are trying to take over one oil pan at a time.Last edited by Bistineau; 02-02-2012 at 08:49 PM.
Reply:I guess sh!t just happens but I don't see how so many alum. pans can get holes knocked in them all of a sudden. Bistineau, maybe you're right,LOL!! Maybe even the German pans are made in china.        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Rocks still made in America!
Reply:They will only take out effeminate aluminum oil pans, not Manly Steel Pans whose TPF (Testosterrific Protective Field) deflects obstacles and protects delicate engine internals.This is merely natural selection. The strong and ductile will survive,  (excepting those made by companies who don't care about corrosion protection and count on their cruise control kickoff switches to burn their vehicles to the ground before their oil pans rejoin the dust of the Earth!)while the brittle and rigid will perish.Last edited by farmall; 02-02-2012 at 11:04 PM.
Reply:I noticed this too. Guess i ought to check all mine today for leaksSafety 3rdGump
Reply:I guess my question about alu. pans is: are they to save weight or better heat dissipation? I can't believe a cast alum. pan can weigh less than a stamped steel one.        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusI guess my question about alu. pans is: are they to save weight or better heat dissipation? I can't believe a cast alum. pan can weigh less than a stamped steel one.        Mike
Reply:Originally Posted by Bistineau They mass produce them at about $20 a pop, then when the terrorists knock a hole in them, most consumers won't even consider the option of getting them welded. .
Reply:Considering those terrorists may be college women, they run on low tires, speed over speed bumps and dips, grinding the bottoms right out of them alum oil-pans. Then they cry like babies because thier engine lights blare in their faces because of no oil.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-24 01:27 , Processed in 0.095118 second(s), 18 queries .
