Tig setup for Miller XMT 304?
发表于 2021-8-31 23:59:11 | 显示全部楼层 |阅读模式
What would I need to use a air cooled tig setup with my XMT 304? How do you control the gas on/off?Thanks
Reply:Weldtech 17V or 17FV tig torch, a flowmeter and hose to reach from the bottle to the torch hose, and the appropriate connection lug. The torch has the gas valve built in. Need gas turn it on and turn it off when you finish welding. That rigup will work with any dc-cc power supply but you will be limited to scratch start.The difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-24 03:01 , Processed in 0.101980 second(s), 18 queries .
