Rock rails
发表于 2021-8-31 23:59:10 | 显示全部楼层 |阅读模式
DWR,You make rock rails... great! Right now I have to many projects going on. I'm going to tackle my own rock raills. My truck came with rock rails. Except I can't use them as a step, there tucked under to far. Brackets are already on truck. What wall thickness is good for tube? What should I get to bend tubbing.Truck weight 7k lbs. SUV type body. I see them for about $1600 a set. I see 1/4 inch flat plate rails and round tub rails. Don't know which to build. You can see me using them in this picture. http://www.enichesoftware.com/I was going to buy a 24k tubing press from HF for $100, below. Modify it for my air over hyd shop press.I'd also like to build a 1/8" notcher, one for flat stock, one for pipe fiting 90 degree only.VernLast edited by Vern2; 01-21-2010 at 11:04 PM.
GMT+8, 2025-12-24 03:01 , Processed in 0.069399 second(s), 19 queries .
