welding projects ornamental and more
发表于 2021-8-31 23:59:07 | 显示全部楼层 |阅读模式
thought I'd post a couple of pics of some projects I've been working on. Attached Images
Reply:Nice work on the railing.  I like the way you did each step.    Sign and manifold look good, too.
Reply:Oops ... double-tapped.Last edited by SpyGuy; 01-23-2010 at 12:12 AM.
Reply:What is the manifold made of? Looks like steel. Nice work."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:manifold is just mild steel for an early hemi engine. I ended up selling it before I got to bolt it up and see if it worked, but the real test is if I can make one out of aluminum.
Reply:Originally Posted by krisk1233manifold is just mild steel for an early hemi engine. I ended up selling it before I got to bolt it up and see if it worked, but the real test is if I can make one out of aluminum.
Reply:Nice work....I would have added this to my previous message, but my editing privileges might be on hold.07 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others... Originally Posted by RhynoBut, if I "all of a sudden disappear....  ...." hopefully I didn't suffer too much....
Reply:No unfortunately I haven't. I also realized that I didn't allow for enough plenum volume and made and 1.5 inch aluminum spacer between the flange and the top plate, which would have made a considerable difference
Reply:Really nice work.
GMT+8, 2025-12-24 03:05 , Processed in 0.103994 second(s), 18 queries .
