2" x 2" 1/4" A500 = hitch receiver tube
发表于 2021-8-31 23:59:05 | 显示全部楼层 |阅读模式
I am looking to buy (online of course) some 2" x 2" 1/4" A500 steel to be used as a hitch I am building.How close is the A500 2"x2" to actually "hitch receiver tube"?I will be sliding this A500 into a female hitch receiver.Please let me know.thanks.
Reply:will work fine. Most commercial hitches are 3/16" wall (.18"). It's the Female side that causes trouble with receivers. The seam on most tube is in the middle of one side. with receiver tubing it's in the corner.I should point out that building your own hitch is not the best idea. to much liability in it, and if something happens your home owners/car insurance isn't going to cover you. Not knowing your welding skill or you equipment we can't tell weather or not this is even something that should be considered by you. Besides. buying a hitch is far cheaper than building one 95% of the time.Last edited by ThorsHammer; 02-08-2012 at 11:44 AM.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Not building an actual hitch building a hitch receiver to I can make a device to can be put into the hitch.
Reply:what kind of device are we talkin about?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerwhat kind of device are we talkin about?
GMT+8, 2025-12-24 03:07 , Processed in 0.210823 second(s), 18 queries .
