Sheilding gas
发表于 2021-8-31 23:59:01 | 显示全部楼层 |阅读模式
What is every one using and why is it your preference. This question is for all metels.If I Can't Weld It!-----It Can't Be Welded!
Reply:It really is not a matter of preference when using a shielding gas.  The factors the depend on which shielding gas is chosen are as follows:1. process used (MIG, TIG, FCAW,)2. Base metal (steel, stainless, Al)3. Filler metal used (ever manufacturer has specific specs on what gas to use with which filler)4. Desired mode of transfer (spray, globular, etc)
Reply:When you come to a point at which you are not sure, just ask.    JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:I'll answer the question.100%argon-- TIG with all metals (which for me is steel, aluminum, and occasionally stainless).  I also use argon for MIG with aluminum.75%argon/25%CO2-- short-circuit MIG on steel.85%argon/15%CO2-- same as above.100% CO2-- same as above.98%argon/2%oxygen-- spray-transfer MIG on steel.Oxygen/Acetalyne-- cutting, heating and (rarely) welding and brazing, also occasionally setting stuff on fire by accident.Propane-- low-temp heating, sweating pipes, blowing glass, setting stuff on fire, fueling the gas bar-b-q, powering propane appliances in the camper.Mapp gas-- same as propane, except not in the bbq or camper.Coleman white gas-- in the camp stove.Butane--  filling re-fillable cig lighters and torch lighters.Kerosene-- very rarely, we have a couple kerosene lamps we light up once in a blue moon. Gasoline--  in the car and all 3 trucks, both bikes, the generator, welder, air compressor, chainsaw, starting campfires, cleaning greasy parts, killing spiders.Diesel fuel-- only in the van. human Methane (farts)-- clearing the room and preventing internal explosion.I use natural atmosphere for everything else.   Works pretty good, sometimes better when compressed.Last edited by DesertRider33; 04-22-2008 at 10:19 PM.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:That about sums it up, Desert. Argon: I use for TIG.  For me, too spendy to use elsewhereCO2:  Wire Feed welding.  Does a good job, and is cheap.
Reply:DesertRider33, what no mention of helium and hydrogen? Hydrogen -- useful for powering "clean 0 emissions" vehicles by allowing others to produce the emissions necessary to create the hydrogen.Helium -- Useful for some specialized welding applications , filling balloons and blimps and mixed for diving.Nitrogen -- major component of air. Also useful in some circumstances to prevent oxidation and displace oxygen.Nitrous oxide -- Just fun.
Reply:I didn't mention the others cause I dont use them, but I forgot about NOX.  Haven't had fun with that in a long time!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:C25 works great for tig on steel. Helium for aluminum after you pass 400 amps.The difference between art and craft is the quality of the workmanship. I am an artist.
GMT+8, 2025-12-24 03:01 , Processed in 0.271559 second(s), 18 queries .
