a video of o/a welded aluminum
发表于 2021-8-31 23:59:01 | 显示全部楼层 |阅读模式
http://www.cut-like-plasma.com/video/Clip_009c_UC.movbacktrack through the link for economically priced Lens information.Last edited by tapwelder; 04-26-2008 at 11:12 AM.
Reply:Great video, I wish more people would post more videos. It really help me to see it rather than read sbout it.
Reply:Neat video and absolutely true. With a little practice in thin aluminum you can run it with no ripples in the weld, it will be as smooth as solder.
Reply:Thank you Tapwelder. What a great video, and some really sound advice with the preheating. Most modern welders don't know much about the virtues of preheat, as all their welding is electronic.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:I wish I could see it!  My computer won't play it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You're not missing much. Better quality video of the same kit can be found at...  http://www.cut-like-plasma.com/info_video_library.htmDifferent videos of the same kit at... http://www.welddownunder.com/video.htmRemember to take your cynical pill before viewing- wouldn't surprise me if there's a video of the Henrob doing the washing up about somewhere
Reply:That Henrob 2000 torch looks intersting.   Although, it looks like it would get your hand very hot if using it for preheating, bending, or cutting thick plate!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-24 03:02 , Processed in 0.086180 second(s), 18 queries .
