dumb chromoly question
发表于 2021-8-31 23:59:01 | 显示全部楼层 |阅读模式
Is there a simply way of telling the difference between chromoly and mild steel? ThanksMillermatic 180AS w/ spoolmate 100Craftsman 110v flux core migGolden Oldy Miller stick welderIn need of a plasma cutter....More tools and junk than i know what to do with!
Reply:no simple ways.  Sorry.  If you grind it, it should throw sparks that look very from those that come from mild steel; just like cast iron does.  But this won't tell you for certain that it is 4130 or any of the other chromoly alloys.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:4130 tastes more lemony than mild steel .insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:That was a very witty comment there chenry, i'll take me a big lick on the tubing tommoro and then i know for sure.     THanks for you help A DAB.Millermatic 180AS w/ spoolmate 100Craftsman 110v flux core migGolden Oldy Miller stick welderIn need of a plasma cutter....More tools and junk than i know what to do with!
Reply:Originally Posted by chenry4130 tastes more lemony than mild steel .
Reply:its not meant to be funny, try tasting a few different.oh and that coke can full of thread cutting oil on the lathe was a real eye openerinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:You all are real cute lolI was asking because a buddy of mine has a wheelie bar he needs welded on and we need to know if it is chromoly or mild steel to fix it.  Ideas??Millermatic 180AS w/ spoolmate 100Craftsman 110v flux core migGolden Oldy Miller stick welderIn need of a plasma cutter....More tools and junk than i know what to do with!
Reply:Originally Posted by Fabc8torYou all are real cute lolI was asking because a buddy of mine has a wheelie bar he needs welded on and we need to know if it is chromoly or mild steel to fix it.  Ideas??
Reply:Maybe call the psychic hotline??MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:get a small piece of the material, heat it red hot, and drop it into some water.  If you can bend it, it isn't chrome molly.  I used to make chisels out of drop off.  very tough stuff.MILLER 330 AB/PMILLER GOLD STAR 130KUBOTA BX24CASE MINI HAY PRESSBENCH MILLHYPERTHERM 45BABY HOSSFELD
Reply:Pre heat it to 250' just at a precaution...Cr will crack.  If it is steel...the preheat won't hurt it to badlyJonesy
Reply:Originally Posted by Jonesy70Pre heat it to 250' just at a precaution...Cr will crack.  If it is steel...the preheat won't hurt it to badly
Reply:I forgot how to make the degree symbol...lolJonesy
Reply:Do the spark test, ring test, file test, do you have a rockwell tester?Have a sample cut and polished at a lab, they can tell you from what it looks like under a microscope.Or keep some mouthwash handy for all that taste testing!! Last edited by tanglediver; 04-29-2008 at 11:30 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-24 04:42 , Processed in 0.216514 second(s), 18 queries .
