Welding 4130 to 1018 mild steel
发表于 2021-8-31 23:59:00 | 显示全部楼层 |阅读模式
Can you weld 4130 chromoly to 1018 mild steel?  If so would i use er70s-6?  Would mis and matching like this be strong or would it be weak?  Also, where is a good place to get tubing at online other than chassis shop? THanksMillermatic 180AS w/ spoolmate 100Craftsman 110v flux core migGolden Oldy Miller stick welderIn need of a plasma cutter....More tools and junk than i know what to do with!
Reply:Originally Posted by Fabc8torCan you weld 4130 chromoly to 1018 mild steel?  If so would i use er70s-6?  Would mis and matching like this be strong or would it be weak?  Also, where is a good place to get tubing at online other than chassis shop? THanks
Reply:Go1lum is dead on. Just use the regular mild filler rod, it works very well in almost every application. And as for tubing online, you are looking at massive costs for shipping. Better you find a local metal supply shop to get your tube at.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Thanks for the help guys, everything worked out great!Millermatic 180AS w/ spoolmate 100Craftsman 110v flux core migGolden Oldy Miller stick welderIn need of a plasma cutter....More tools and junk than i know what to do with!
GMT+8, 2025-12-24 02:59 , Processed in 0.206042 second(s), 19 queries .
