Acorn Platen
发表于 2021-8-31 23:58:53 | 显示全部楼层 |阅读模式
I just bought an Acorn Platen off of Craig's List. Does anyone know how much a 5' x 6' weighs?RichConnecticutLincoln SP-175 PlusMiller Dynasty 200 DXMiller Syncrowave 250Miller XMT 304Miller Millermatic 350PHypertherm Powermax 1000
Reply:rich    i have a 5 x 5 acorn style table, on an angle iron frame, with 3 " pipe legs, weighs well over a ton!        Bob
Reply:I have a 5X5 and the top is 2200lbs. Its not an Acorn though. I think it is much thicker then an Acorn, maybe not. I built my legs out of 1/2 thick 4x4 angle and it weighs about 800lbs. Oh, man. I hope you are going to pick it up. You will get socked on the shipping.Welding everything, from the crack of dawn to a broken heart.
Reply:2600lbs give or take depending on the thicknessVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-24 03:45 , Processed in 0.103194 second(s), 18 queries .
