Si Bronze on cast iron exahaust manifold repair
发表于 2021-8-31 23:58:52 | 显示全部楼层 |阅读模式
I am going to repair an old tractor manifold.actually I already welded on a broken off ear for one of the exhaust ports, but it went very poorly.  poor access, and a lot of re-grind and re-weld.  it's two parts bolted together and the WILL NOT come apart.  so I'm asking to avoid problems with the next part.I am using ERCuSi-A filler.when I tried my tig I was having all sorts of awful result.  I think mostly due to poor access, so I switched to oxy fuel and I did OK.  Still had **** adherence on the first few tries.  Ok finally, seems to be well stuck together anyway.There is a substantially long crack down the back of one of the runners but access to about 1/2 of it is also bad.  but I think I can do it with the oxy fuel.  no way the tig.my question is 2 parts really.#1 is tig with the ERCuSi-A  even a legitimate thing to do with cast iron exh manifold?I seem to remember researching and  buying it for this sort of project, but it has been so looooong, and I'm a hack and I forgot.#2 and if I use the torch again, what sort of flux.  I have Solar, but the last time the solar really did not work to well,    I also have Harris Stay-Silv 700*1800FPreheat necessary?   post weld cool down precaution?it's a big bastard and I don't have a vermiculite enough to cover it.  but I could get some?I thought the braze was soft enough (or not contracting ehough) to require PWHT.Thanks,
Reply:Originally Posted by dsergisonI am going to repair an old tractor manifold.actually I already welded on a broken off ear for one of the exhaust ports, but it went very poorly.  poor access, and a lot of re-grind and re-weld.  it's two parts bolted together and the WILL NOT come apart.  so I'm asking to avoid problems with the next part.I am using ERCuSi-A filler.when I tried my tig I was having all sorts of awful result.  I think mostly due to poor access, so I switched to oxy fuel and I did OK.  Still had **** adherence on the first few tries.  Ok finally, seems to be well stuck together anyway.There is a substantially long crack down the back of one of the runners but access to about 1/2 of it is also bad.  but I think I can do it with the oxy fuel.  no way the tig.my question is 2 parts really.#1 is tig with the ERCuSi-A  even a legitimate thing to do with cast iron exh manifold?I seem to remember researching and  buying it for this sort of project, but it has been so looooong, and I'm a hack and I forgot.#2 and if I use the torch again, what sort of flux.  I have Solar, but the last time the solar really did not work to well,    I also have Harris Stay-Silv 700*1800FPreheat necessary?   post weld cool down precaution?it's a big bastard and I don't have a vermiculite enough to cover it.  but I could get some?I thought the braze was soft enough (or not contracting ehough) to require PWHT.Thanks,
Reply:I got antsy and tried the stay silv.petersn's #2 for cast iron.... I googled but all I could find out is it is a "black flux" high temp flux, but I cant find much info.and the harris sta-silv is a "black high temp flux" also....  and..... I have a can!         -and I just tried it.  it worked beautifully.  it wetted out real nice with the torch.    and I wrapped tinfoil all around in several layers to cool slowly.thanks so much.  it worked so much better.
Reply:I had a exhaust manifold crack on an old tractor.  New used was not available.  I bolted the manifold to a piece of 1/2" X 8" flat.  I preheated the manifold and the flat with a rosebud tip then used some OA cast iron rod (it comes in 24-30 inch length and measures about 3/16" square) with the flux that was recommended for the application then filled in the V of the crack and broken off ears.  The cast iron of the manifold is heated to a dark cherry red and the cast rod is melted into the orginal. I covered the entire piece to keep the heat contained for a slower cool.  The first manifold I ever tried worked like a champion after welding the first time.  The second one off a ford pkup taught me much humility on welding.
Reply:lots and lots of humility to be had when welding cast
GMT+8, 2025-12-24 03:47 , Processed in 0.071085 second(s), 18 queries .
