Receiver Mounted Toilet Seat
发表于 2021-8-31 23:58:44 | 显示全部楼层 |阅读模式
I seen one of these in a catalog and decided to build one to give as a gag gift to someone for Christmas.Last edited by dmboxerdog; 12-22-2009 at 08:12 PM.
Reply:Lmao! MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:HAH !Awesome....  looks sturdy enough to crap on while doin' 55 !Cheers,/Jman...Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Thanks!!!! I was having a hard time figuring out what to get my brother in law!!!
Reply:DRIVE BY CRAPPING!  Brilliant!Realgear 140 MIGMore DeWalt tools that I prolly needDIY 160 amp 40 OCV MOT Stick Welder
Reply:AHHHH the joy of opening your x-mas gift. A BUMPER DUMPER.TJ
Reply:Not recomended for low riders"Any day above ground is a good day"http://www.farmersamm.com/
Reply:DOT regulations state that while moving, tailights must be attached to both knees"Any day above ground is a good day"http://www.farmersamm.com/
Reply:the seatbelt law will be strictly enforced"Any day above ground is a good day"http://www.farmersamm.com/
Reply:the mother-in-law package includes optional fuzzy seat cover"Any day above ground is a good day"http://www.farmersamm.com/
Reply:let Hertz put you on the toilet seat"Any day above ground is a good day"http://www.farmersamm.com/
Reply:you can get a seat belt off a forklift...
Reply:Originally Posted by farmersammDOT regulations state that while moving, tailights must be attached to both knees
Reply:Seriously- you need to add a seatbelt.  That would be even more hilarious and be the finishing touch. Go to a wrecking yard and find a lap belt- it would be PERFECT!Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Also, to meet DOT regs, it needs a micro-switch wired to disable the ignition when the seat is in use.
Reply:Originally Posted by WeldordieAlso, to meet DOT regs, it needs a micro-switch wired to disable the ignition when the seat is in use.
Reply:Originally Posted by BoostinjdmAnd hazards to let those around you know to stay clear.
Reply:Farmersam,  You got it wrong.  For the mother-in-law you need a quick release from the cab.
Reply:These have been around for several years.  Surprised you're not gettig the camouflage model.America Needs AMERICA'S Oil!!!"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Reply:Bad enough someones always pissing on my wheels...I better pass on one of those
Reply:I have a hunting buddy who built one of those....was perfect...I think a more modified one will have wires hooked to the tail lights and coiled under the seat to make it heated
Reply:Mud flaps?
Reply:Originally Posted by SupeMud flaps?
Reply:Top Gears Bumper dumper.  There is more to the clips just watch more of the Polar special, GREAT for laughs!
Reply:Ya know as a guy gets older squatting unsupported is problematic.  This is a good product
GMT+8, 2025-12-24 03:48 , Processed in 0.111412 second(s), 19 queries .
