Fire box for the boss
发表于 2021-8-31 23:58:44 | 显示全部楼层 |阅读模式
Its been slow at work for awhile now, so the boss had me make him a fire box for his camp. All he wanted was a 3'X4'X8" box, but I added a skid and a grill, and when he saw what I had added he was excitied. Nothing fancy but made the boss happy.: Attached Images
Reply:Hot Dog! Cool design you came up with there.  Let us know how the burgers turn out MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:That's cool.  I like the little swing out grill.Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Originally Posted by BrinkHot Dog! Cool design you came up with there.  Let us know how the burgers turn out
Reply:We have one of those thats round about 1 foot off the ground Works great and the food is good too. great idea i need to make another one for here at the house.Millermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Thanks guys,  He was more impressed with the skid than the grill, because he said he doesn't have to shovel the box out to clean it, just drag it away, flip it over, drag it back.
Reply:If the boss is planning on leaving this at the campsite, you might want to drill a hole in each corner.  Looks like the corners are fully welded and may hold a little water if the box isn't perfectly level (which it won't be).I've used old tractors wheels in a similar fashion.  Roll them out to the campsite and lay them over.  Sometimes you have to jamb something under the edge, or dig a little gap to get good airflow.  Looks like you've already got this handled with the side slots.  Also the gap at the bottom doesn't seem to be needed on narrower wheels (15inch and less).  A tractor wheel, a piece of catwalk grate, and a few cast iron skillets makes some of the best food.Any reason you didn't put in a grate to hold the wood up from the ashes?Last edited by AndyA; 02-05-2010 at 03:57 PM.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:AndyA, yes I should have drilled some holes, but I don't think it will be out in the weather, he has a covered patio he puts it under. As for the grating, we didn't have any and he said it wasn't necessary.
GMT+8, 2025-12-24 03:47 , Processed in 0.118385 second(s), 18 queries .
