Fire screen metal materials. Where to buy cheap? Or a substitute?
发表于 2021-8-31 23:58:39 | 显示全部楼层 |阅读模式
Looking for metal to make a fire screen for a firepit. http://www.mcnichols.com/product/360...avc:plainsteelSuch as that .. 4 sq ft is about 10 dollars any change of finding it cheaper or am I wastin my time looking?ThanksSent from my Xoom using Tapatalk
Reply:Looked at the link.Looks pretty decent - but do a GOOGLE search for wire mesh screen - there's quite a few, and in colors.Here's one for stainlesshttp://www.twpinc.com/wire-mesh/TWPCAT_12Remember you want a very fine weave to stop sparks and take the heat of a fire and a fire spark over a long period of time.
Reply:Hmm seems i found a roll at lowes in the garden section . 23 gauge and 30 sq ft for 17 dollars. Only prob is that its galvanized. I may buy it.and try to remove it with the vinegar methodAny one think its a bad.idea?  Will I be able to completely remove.the zinc because it will be used as a fire screen on a fire pitSent from my DROID X2 using TapatalkLast edited by bobjenkins; 02-17-2012 at 12:42 PM.
Reply:Why remove the galvanizing?   Isn't it going to be outside?
Reply:Originally Posted by KelvinWhy remove the galvanizing?   Isn't it going to be outside?
GMT+8, 2025-12-24 03:47 , Processed in 0.071554 second(s), 18 queries .
