flux core?
发表于 2021-8-31 23:58:37 | 显示全部楼层 |阅读模式
I just bought a firepower 130 fp. I am running .030 flux core wire. Not familiar with flus core , is it best to push or pull when welding with flux core? Thanks , Randy
Reply:It don't matter as long as you take the time to prep it and get good penatation. If you can try to push because you can see the puddle better. www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:i was  always told to pull never push cause it is like the 7018 rod you can imbed slag under the weld remember to run it ENLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Pull.
Reply:When there is slag, you drag."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:good way to put itLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Originally Posted by mechanic416It don't matter as long as you take the time to prep it and get good penatation. If you can try to push because you can see the puddle better.
Reply:pull metal,push aluminum.
Reply:Thanks for the replies. Been welding since 1997 and never welded with flux core. Tested the machine before I bought it and I pushed the puddle, looked good but didnt slag over the top much. Thanks, Randy
Reply:Originally Posted by Ron Padillapull metal,push aluminum.
Reply:Originally Posted by Warroad140Say what are we talking women or welding?
Reply:Apparently there are very few WELDORS on here that have used flux core wire or just don't know how! Try welding vertical down or vertical up dragging!!YA, Wrong advice My A$$www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Miller Electric recommends "drag"  with flux core.
Reply:Originally Posted by mechanic416Apparently there are very few WELDORS on here that have used flux core wire or just don't know how! Try welding vertical down or vertical up dragging!!YA, Wrong advice My A$$
Reply:Typically I drag flux core.   But when I get to certain spots I will go straight in or push.  On the flatbar stiffiner I dragged the puddle.   for the overhead I pushed the weld in because the type of weld I am doing and cosmetically I want it to look flat.  Second picture I Dragged and Dragged  Flat is much easier.  Out of position it depends on what the weld joint looks like. Attached Images“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:Here some of my practice beads before a test.5/8" Mild Steel Plate    3/32" copper nickle flux core   350amp 200 on the wire speed "pulled"Last edited by justinT; 02-07-2012 at 12:20 AM.
Reply:I appreciate all the feedback on fluxcore welding. Great pictures too. I pretty much just wire weld anymore, steel and aluminum, in a trailer repair shop. every now and then i get to do a little steel tig welding which is something else I want to get back into. Up until the last four months or so I was in management for the last eight years, tryin to get back up to speed. Thanks, Randy
Reply:Originally Posted by Stick-manWhen there is slag, you drag.
Reply:Originally Posted by assassin_worksit is wrong you want to push with flux core all i ever run is flux cause my work is all done outside so i do know how to run fluxcore and i did do v ertical up and down not very much of a drag but yes virtually heres an up  and a down p.s. it was all done on a cc power supply  and my suitcase 12vs
GMT+8, 2025-12-24 05:11 , Processed in 0.115565 second(s), 18 queries .
