Circuit Question
发表于 2021-8-31 23:58:37 | 显示全部楼层 |阅读模式
I am trying to figure out the amperage of the 220 circuit in my garage.  When I look at it in the breaker box, there are two 30-amp breakers with one long plastic piece connecting them (the part that you switch it on and off with).  Is this a 60-amp circuit or 30-amp circuit?
Reply:30 amp two pole breaker.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:That's what I was afraid of.  I was really hoping it was a 60 amp...  Thanks!
Reply:Check the wiring gauge and IF this is for a welder ONLY circuit the wiring may meet code for the code exception granted for welding equiment and you can just add a 60 amp breaker. If not, and the panel is in the garage, its easy enough to install a new circuit run with the proper wire gauge and breaker. Don't just blindly add a 60 amp breaker without first checking your wire gauge.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:WyoRoy, unfortunately, the breaker box is on the other side of the house.  This circuit has been sufficient for my Hobart 187 and 50 amp plasma cutter.  I am saving for a metal building to use for tractor storage and welding shop.  So, I think I am going to wait until I get this building and install a 100 amp circuit out there, as I really would like to have the capacity for an old transformer based 250-300amp stick welder.  I will have an electrician wire this shop though.  Thanks for
Reply:Morgaj, just curious, is your breaker box a Federal Pacific by chance and what size wire is going to the garage?  Reason I ask is that this breaker is handling your existing load and not tripping.  Bob
GMT+8, 2025-12-24 03:44 , Processed in 0.102247 second(s), 18 queries .
