TIG welding 20 gauge sheetmetal question
发表于 2021-8-31 23:58:35 | 显示全部楼层 |阅读模式
I'm fabricating caps for the walls on a powdercoating oven I am making.  The walls are 48" by 47" but my sheetmetal brake is only 30" wide, therefore I have to fabricate the caps from 2 pieces.  So when I weld the pieces together (20 gauge sheetmetal, TIG, 30amps), I get some deviation towards the open side.I tried clamping an iron angle inside the closed side but I still get some deviation.  Is there any way I can avoid this so that the caps stay straight?Thanks in advance (I am relatively new to all this and slowly learning).
Reply:Low heat and multipass might help.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Yes, offset the parts before you weld.  Seat of the pants will show you how much. David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RYes, offset the parts before you weld.  Seat of the pants will show you how much. David
Reply:Originally Posted by x1rideryou mean put some angle between the pieces the other way so that it ends up straight after the welding is done, right?
GMT+8, 2025-12-24 03:32 , Processed in 0.106628 second(s), 18 queries .
