oil drain and tranny jack make over
发表于 2021-8-31 23:58:32 | 显示全部楼层 |阅读模式
Well I got a two post lift a few months ago with a new lift comes new tools.The lincoln oil drain tank work awsome, but the top is crowned . Everything you set on it falls to the floor.# 2 tranny jack a must have 5 days out of the year. The other 360 days you trip over it and push it around. It's too big to throw up in the attic and to nice to put it outside.Back to the oil drain. I took an old well tank and,cut it up to make a dish for setting wrenches on, and put 2 grease gun holsters on it. I welded a 1/8 pipe nipple on for a drian. I'll put a hose on with a plug .Tanny jack is now tool cart. made with 1'' angle in a 30'' octagone. I put 8 j-hooks for hanging tools. I plan to cut a piece of stainless steel for the top . I hope the paint it this weekend. John Deere yellowdaye Attached ImagesLast edited by tigmusky; 02-06-2010 at 08:33 PM.
Reply:more pics Attached Images
Reply:wow this one a barn burner Attached Images
Reply:kool i just bought that same lincoln drain pan.... i am still looking for a trans jack but they run about 1k or more new...Adam MMorales Ranch
Reply:Originally Posted by ItsAdam1kool i just bought that same lincoln drain pan.... i am still looking for a trans jack but they run about 1k or more new...
Reply:got'em done Attached Images
GMT+8, 2025-12-24 03:31 , Processed in 0.110987 second(s), 18 queries .
