my new built shotbag stand
发表于 2021-8-31 23:58:31 | 显示全部楼层 |阅读模式
This is my new project that I just finished. It matches my English Wheel. I used a 1 1/4 inch thick by 14 inch diameter steel plate and welded a 5 inch o.d diameter  by .250  thick wall. I then cut the tubing pieces that hold the hammers to the sizes that I wanted then welded them to the center section, and then welded the section to the main tube.  Lastly, a plasma cut 19 inch diameter plate 3/8 inch thick was welded to the top of the stand, and I used a scrap piece of  metal grating inside of the center section to hold all of my dollies. It was then prepped and painted. Can you tell what the center section was made out of ? Attached Images
Reply:very cool looks like part of a bike frameHH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:B E A UTIFUL... very nice work.Center section looks like a bike frame to me as well....Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Originally Posted by SilveradoB E A UTIFUL... very nice work.Center section looks like a bike frame to me as well....
Reply:neat.. i put one together along similar lines..3  legs fore stability...not quite finished but in  regular use.. i put a square hole in the top to receive post dollies, similar to an anvil.. Attached Images
Reply:Awesome JOB Guys... !I too am looking at buiding one of these for copper mostly...  Where can a Guy find a NICE shot bag at a decent price ?Cheers,/Jman...Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:try tinmantech.com
Reply:Those are great! Does that painted one have adjustable footing, or did you manage to keep the plate perfectly flat? It looks to be a slip on flange, but no holes. I suppose you would have a tough time warping that.BillUA Local 598
Reply:so when do we get to see some formed/shaped metal projects from these!!!!!!!!!!!!!!!!!!!!!!!!!!!!HH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:That would be nice.....
Reply:also daggertools.com
Reply:Originally Posted by WHughesThose are great! Does that painted one have adjustable footing, or did you manage to keep the plate perfectly flat? It looks to be a slip on flange, but no holes. I suppose you would have a tough time warping that.Bill
Reply:Originally Posted by kenklingermanso when do we get to see some formed/shaped metal projects from these!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reply:welders first project is usually a cart..i guess anyone  that starts hammering sheet metal makes a bowl ..i made this  because i needed it.. it catches bacon grease out of the black pan, and i can tell you it sees a lot of use.it evolved, i went back 3 or 4 times to make steeper sides/more volume, because i eat a lot of bacon.. Attached Images
Reply:That looks like a sports cup! yikes, sharp edges!HH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:Awesome stand.I need to build one of those very soon. Thanks for the cool pic'sMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
GMT+8, 2025-12-24 03:43 , Processed in 0.065642 second(s), 18 queries .
