Al wheel repair
发表于 2021-8-31 23:58:29 | 显示全部楼层 |阅读模式
Customer said "something" went thouugh tire and hit wheel fracturing area and making it "pooch" out. Drilled out fractures, ground clean the gouge in bead sealing area. I welded gouged area first and held torch on for a little while so it would preheat edge of casting. This is evident in pic of outside bead area, the powder coat is burnt. Then welded hole inside and out. Flapwheel'ed area.Peter Attached Images
Reply:rest of pics Attached Images
Reply:Originally Posted by castweldCustomer said "something" went thouugh tire and hit wheel fracturing area and making it "pooch" out. Drilled out fractures, ground clean the gouge in bead sealing area. I welded gouged area first and held torch on for a little while so it would preheat edge of casting. This is evident in pic of outside bead area, the powder coat is burnt. Then welded hole inside and out. Flapwheel'ed area.Peter
Reply:Subaru?HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Originally Posted by RhynoGreat repair!  What kind of AL was the wheel?-Rhyno
GMT+8, 2025-12-24 03:47 , Processed in 0.097062 second(s), 18 queries .
