Sugaring? Wth?
发表于 2021-8-31 23:58:28 | 显示全部楼层 |阅读模式
I was tig welding some 16 gauge 304 SS today making a pan..... I couldn't get it to quit sugaring... I was back purging and it still looked like crap.... I have never had a issue like this welding 316 it always look great on the back side?????  Any one else ever experienced anything like this????????
Reply:bad gas or bad gas coverageVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Too much heat?Leo
Reply:Originally Posted by NVWToo much heat?
Reply:Argon is heavier than air, you should introduce argon at the lowest point and have an escape hole the same size as the inlet at the highest point, air can get mixed in if you do this wrong.Welding/Fab Pics: www.UtahWeld.com
Reply:More purge, and purge longer.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-24 03:44 , Processed in 0.103335 second(s), 18 queries .
