Millermatic 120
发表于 2021-8-31 23:58:25 | 显示全部楼层 |阅读模式
Saw this machine on CL, anyone know a quick way to check power output on it and drive roll function, It has no MIG gun or bottle. guess I could take a MIG gun with me? price is best offer. Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I imagine you could short the pins that go to the gun, then look for the rollers to spin and take a volt meter across the terminals.That wont tell you if it is really functional (it still might not kick out enough amps), but it would be a good indication.
Reply:Are you bored or sumptin?seems like you got plenty o' machines to work withEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I don't know, just like picking them up for cheap money and getting them running, better than the scrap pile, bought this one for $65 . Put a gun on it, fixed some really poor looking wires and connections and Walah, running MIG welder, by the way far superior to any $90 HF MIG, do you agree? Now if it sits around so be it, if someone needs to borrow it fine,if someone want to buy it for 2-300 everybody is better off , Agree? Some guys redo tractors, Me it's Welders and Compressors. HaHa  Currently sits in my mobile enclosed trailer and can run off my Weldanpower with my double plug adapter(amperage draw) so if I run into a sheet metal issue out there, just buzz it up. Don't have to pack or unpack my MM251.Last edited by kolot; 02-20-2012 at 10:07 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by Broccoli1Are you bored or sumptin?seems like you got plenty o' machines to work with
GMT+8, 2025-12-24 03:44 , Processed in 0.091290 second(s), 18 queries .
