miller syncrowave 250 problem
发表于 2021-8-31 23:58:25 | 显示全部楼层 |阅读模式
Hi everyone, I have no power at the 14 pin connector. The machine welds fine on stick. any ideas, thank you.
Reply:A 250 sync we have at work recently came back from servicing. It needed a new main board,JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by kevhead63Hi everyone, I have no power at the 14 pin connector. The machine welds fine on stick. any ideas, thank you.
Reply:Thats correct, I dont know to much about electronics. All the switches are in the correct position. I also checked the amp control switch and it seems like it is ok. All three relays are broken off and hanging there. Is there away to test relays? thanks
Reply:If components are hanging loose, I'd want someone who understands circuitry to check all the wiring. I understand basics but not detailed IC's. Member duaneb55  is the resident expert on Miller equipment; perhaps a PM to him could make him aware of this thread and he could give some better advice. To answer your direct question, yes, individual relays can be tested. You need to know their specifications either from data on them, by looking up their numbers, or by knowing what is used in that position. It does, of course, require some basic test gear and knowledge of its use.
Reply:I had the meter set on DC, I just checked it on AC and I do have 24 volts. I cant scatch start tig. Im thinking it must be in the tig gun cable, Any way of testing it? Thanks
Reply:I think you've got bigger problems than just with the machine.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:the tig torch has a fuse block on it and the fuse wasnt blown,but it was cracked at the bend. changed it out today and it welds fine. Thank you all who helped
GMT+8, 2025-12-24 03:46 , Processed in 0.106537 second(s), 18 queries .
