back up power
发表于 2021-8-31 23:58:05 | 显示全部楼层 |阅读模式
here is what i have been working on. It is 2 back up diesel generators.fuel lines Attached Images
Reply:12" stacks Attached Images
Reply:coolent lines Attached Images
Reply:Hope you have a disconnect switch?
Reply:You do the plummin'? nice work....Mike
Reply:nice! bigass turbo on that generator too!
Reply:Very nice, don't forget the transfer switch.
Reply:holy crap!  whats thats beast have to power?Realgear 140 MIGMore DeWalt tools that I prolly needDIY 160 amp 40 OCV MOT Stick Welder
Reply:What make are the engines?                                           MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Wonderful job in a confined area.I was looking at this early on today, and wondered where the heat dissipated from the radiator goes.  Does the room have to be opened up to ventilate it?And how much added backpressure is built up by the needed angles in the exhaust system.  I know there's no way around it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:don't know to much about them i just burn't the rod on the pipe. they stay cool by sucking in fresh air from out side throw that tin intake in front of the rads and pumping the coolent the them 2 1/2 lines throw the basement to a cooling "thing" out side
GMT+8, 2025-12-24 05:02 , Processed in 0.077797 second(s), 18 queries .
