Good quality Mig wire?
发表于 2021-8-31 23:58:04 | 显示全部楼层 |阅读模式
Ok I made my decision on a Lincoln 350MP for a stick/mig machine.I need a little education on Mig wire.What im doing ranges from 1/8-3/8 mild steel. every once in a while i might weld a little 14ga. or 1/2 plate.  I will do the best I can to prep my welds but sometimes i will have to weld on some stuff that is a little rusty. This might not make a difference on your input i just thought i'd throw that in there. Also Im used to welding with 6010 and 7018 so anything with a strength around that area is fine.On my limited knowledge I've heard lincoln L-50 is good.Probably be running argon co2 mix, i guess 75-25 is normal...
Reply:http://www.mylincolnelectric.com/Catalog/consumableseries.aspx?browse=104|1791|Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:This is the wire i use, cheap and does a great job...Bobhttp://www.usaweld.com/index.htmBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Broccoli1Thanks for the site, I had already seen that. But it doesn't really help me all that much, I was more or less just looking for some personal experience, with what im doing.
Reply:if your just starting out wanting to learn about GMAW try these two. i would suggest running hard wire for your thinner applications. Any er70s-6 name brand wire. 100% co2 this is the cheapest gas. no need to worry about transfer mode at this point if you go with the two different processes.second give metal core a try (e70c-6m h4) using 75%ar  25%co2. it works very well when not working on the cleanest metal. this is for your thicker applications and can deposit like flux core without the issues of slag.
Reply:L50 is classified as ER 70-3 and is ok for most structural, Pipe ER 70S-2.  I don't think Lincoln makes a S2 wire, or they did not use to.    JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-24 05:03 , Processed in 0.093430 second(s), 18 queries .
