a couple pics of welds with hh 187
发表于 2021-8-31 23:57:59 | 显示全部楼层 |阅读模式
heres a couple of pics of welds using a hh187. comments or criticism are welcome Attached Images
Reply:they look ok. the second small weld you didnt fill in the crater at the end of the weld, could cause a stress crack. try working on your positioning it looks like you are turning the gun instead of moving the whole thing
Reply:They certainly look fine to me. Looks like you have a good touch with a good machine there. (It's sure tough to use this website anymore. It has slowed down terribly, but I digress.........)
Reply:sorry dreamcatcher i will try to do better next time. i was really just playing around not trying to make it perfect.
Reply:You obviously have good penetration.  They're very consistent and and shiny clean.  Nice job!Old horsebarn for a shopBig scrap pile out backMiller Syncro200Lifelong collection of toolsBunch of other crapUnderstanding wifeUnderstanding neighbors
Reply:Looked great to me also. The HH 187 is a very nice welder. I really like mine.  I welded some with one of the predacessors a few days ago the HH 175 and it was easy to tell from the start that the HH 187 was much nicer to weld with.
Reply:that is the first time i have welded since late january when i started a new job doing machining at my work. i have done better.
Reply:Welds look good and consistant. In the second pic top weld showing the back of a groove weld. Gap the weld a little more and it will penetrate completely through the back side of the base metal. What thickness of material, gas, direction of travel? On the T joint try a cursive O or L gun manipulation pausing a little more at the lower edage of the weld. My .02 worth
Reply:Good looking welds, the weld metal should flow through the gap in the back, keep your contact tip as close to the weld as possible to acheive this effect.
Reply:Those welds look great to me. But I've only been welding about 1 1/2 years [hobby/weekend].Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:The welds look great. Nice job.Do you ride the little baja bike much. The one in the back ground of the first pic.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:that is my son's minibike in the background. he rides it when he isnt in trouble or grounded
GMT+8, 2025-12-24 05:02 , Processed in 0.228916 second(s), 18 queries .
